gar
 - Ann Arbor, Michigan
 - EE
130110-1552 EST
Searching on Google for smart meter output data I came across this:
http://emfsafetynetwork.org/?page_id=1280 .
There are photos and references to many smart meters that are blamed for starting fires. In many cases I suspect the smart meter is not the cause. Very poor analysis and reporting on the problems. Many of the comments are by home owners that want to blame the meter.
Close reading of some of the references indicate that part of the problem results from unqualified persons installing the meters. In one case it was clearly an arc flash on installation (plugging in) the new smart meter. Another case was loose wire or wires terminating in the meter base.
It would be useful to know if there are really instances where the meter itself actually was the fire cause.
There needs to be much better analysis and reporting on the actual causes of these fires.
