- Licensed Electrician
Rodger that; which is what makes the front to front so cool. It's compliant.Assuming the mini's are both on conduit, back to back would be a code violation.
'Splain this some more please. I'm not getting what you are meaning.
Are these something you buy, or something you make using your own strut?
Its the two conduits on the left of the picture .First I set a steel drop in anchor to the ceiling and droped threaded rod with a cowboy to the back to back 90*,then I attached a cowboy to the conduit and with two nuts I attached threaded rod down to the conduit below it and attached a cowboy to that conduit.I was just woundering if this was code compliant It saved me time bc I didnt have to go grap the hammer drill and cord to set in anouther anchor.
the back to back 90 is supported withen 3 ft of the box the 90 kick up is supported a little futher ill hang a hanger for it or do what u mentionedok thnks for your time ill suport the conduit from the ceiling the way you mentioned and make shure im withen 3ft
Mount one with the tabs down and next tabs up using one machine screw to clamp both.
One conduit in each minnie.
The machine screw supports the second minnie which now has an empty mounting hole facing down... which in turn could be bolted to yet another minnie...
Also, what is up with not having a strap on those conduits within 3 feet of the box?![]()
