Thabiso
- South Africa, Cape Town
Part A - Higher order harmonics (greater than 13th)
Part B ? Measuring harmonics with Capacitive Voltage Transformers (CVT?s)
On networks with voltages of 220 kV and higher, voltages are measured with CVT?s. CVT?s do not have a linear, flat frequency response and therefore measurements are only accurate close to nominal system frequency (i.e 50 Hz/60Hz)
:roll:Your input is highly appreciated
- What are current practices for measuring voltage harmonics on a utility level?
- Eskom/Locally
- Internationally (i.e what are the standards)
- Does anybody require measurements beyond the 13th harmonic
- What are the effects of higher order harmonics on:
- Utility equipment
- Customer equipment
- What equipment generates higher order harmonics?
- What are the risks associated with higher order harmonics at present specifically for South African Utilities given the long transmission lines and the installation of capacitor banks on EHV? What impact do capacitors on the transmission network have on harmonic levels?
- How can accurate harmonic measurements be taken via CVT?s ?
- What is the theoretical concept underlying measurement of harmonics via CVT?s
- Are any commercial devices available that enables these measurements?
- What are the costs?
- What are the operational hurdles associated with such devices?
