Ok I'm an electrician with limited (no pun intended) boiler experience. Virtually none really.
I don't know the codes but know how to do basic low voltage wiring.
SO here's what I need to do. I have an Aquastat that is wired to a low water cutoff. (See Aquastat photo).
There is a white 4 wire from that Aquastat that goes to the low water cutoff (See Low water cutoff photo and Low water cutoff inside cover photo).
Ok so the issue is this. This boiler has also now two zone valves installed to be controlled by two thermostats. One's existing and the other is new. They are both just two wire thermostats. The zone valves are these valves (See zone valve photo). The zone valves have 2 red wires and two black wires. I'm assuming one set is 24volts power and the other is contacts for the t stat.
I'm going to have to rewire the entire boiler I believe. Any advice would be appreciated
