- Tennessee NEC:2017
- Semi-Retired Electrician
If a person wanted to install NM cable between a metal roof and the decking under it, assuming firring strips between the two, is there a code article prohibiting it?
Other than a bad idea, IMPO, because of heat, I can't seem to find anything that says you can't.
If it is permitted, would you have to derate the conductors for heat?
This would be in an open raftered ceiling.
