If a twist lock receptacle is within 6 feet of a sink, is the only way to put it on GFCI protection is through a GFCI circuit breaker?
He has a twist lock receptacle.
Yes, and either a usable or dead-front GFCi upstream of that would fit the bill.
But he did not specify voltage, circuit rating, or phasing.He has a twist lock receptacle.
Those are both rated 250V, so no GFCI required (assuming your not using the L6-20R for a 125V circuit).One is NEMA L6-20R & one is L6-30R
No.Another question, if equipment is not near a sink but has a water line in it, does it have to be on GFCI?
No.
