knjelectric
- portage, michigan usa
I have a customer that bought a used commercial oven without telling me. He is
within his rights to do this. The problem is it is 3ph 208 v. His service is 3ph 240v.
This unit has a nameplate rating of 200 a. The 2 conveyor motors can be rewired to the higher voltage. My question is how do I compute the current draw at the higher voltage? If I use straight math and think the higher voltage the lower current it would be 173 a. But if I use ohms law I come up with app. 240 a. I have talked with a few good electricians and we are all scratching our heads. One gentleman
brought up the point that if you increase the voltage on a filiment (light bulb) you will shorten the life of the filiment or burn the filiment (resistor) out. We need a learned person to put this problem to bed. We all have grey hair and dont need any more. Thank you in advance. Jim KNJ Electric p.s. I have thought of a step down transformer also but still need to know the math to get an accurate draw on the service
