JustWork
- New Jersey
I have one overhead 400 amp residential single phase service figured to be fed from overhead with paralleled 4/0 cu in 2.5" pvc to the service head. Both panels will be located approximately 20 feet from the meter location the meter will be located on the exterior of the dwelling and the panels will be located on the interior. We are Looking to install two 200 amp disconnects one on each side of the meter pan which we will be each disconnect with 3/0 cu from double lug's on the load side of the meter. We would then use 4/0 aluminum SER from the load side of the disconnect to their respective panels. I would use a #2 grounding electrode conductor. I have installed 400 amp underground services back to back this would be my first 400 amp overhead sub feed and wondering if there were any other input. Thank you
