brother
I was reading the 2011 NEC, 312.8. It list the switch (along with overcurrent devices) enclosure as being required to have warning labels when there are feed-through conductors.
I understand the intent, because I have seen panels that have this. But a guy asked a good question. Do simple snap switch boxes have to have this label as well? It's rare I would feed-through a switch box but sometimes its quicker and easier to do this. So if one does this is it required to have the label to tell where the closest disconnect is?
If you followed the 'letter' of the code, then why aren't receptacle boxes required for it too? I don't think the CMP intended for that to be used in that fashion, but the code says what it says. What say you? It appears to me the language could use some improvement.
