holychicken
 - NYC, NY
Hello all, first post.
My education is in computer engineering and have focused mainly on embedded programming, both for processors and FPGA/ASICs. I kind of got thrown into the world of transmission and distribution engineering. So I pre-apologize if some of my terminology is wrong/confusing and if I state things that are extremely obvious. I don't apologize for being wrong, that's why I'm posting here.
Assume a 13kV primary and 120/208V secondary.
I kind of understand what would happen if we have a single delta-wye transformer feeding a single load and a fuse upstream of the primary is blown. However, I work on secondary network distribution systems where we have many delta-wye transformers all simultaneously feeding the same load. I am confused as to what would happen in the case of a blown fuse upstream of the primary winding on a single leg.
A little more information, the protector opens a connection between the secondary side of the Delta-wye transformer and the actual network.
If the protector is open with the blown fuse, I imagine it would look a lot like a single delta-wye transformer powering a single load, just a small load that equals the magnetization current of the transformer.
Where I get confused is when the protector is closed. I would assume the secondary side of the delta-wye transformer would remain in its normal balanced state (ideally, a positive sequence of 120 V @ 0 degrees). But what would happen with the currents? And what would happen with the voltages on the delta (primary) side of the transformer? I am thinking that on one leg you would see normal forward current, but on the other two legs you would see a reverse current equal to the magnetization current of the transformer. Is this thinking even remotely correct?
Thanks for your consideration.
