Does the NEC allow running thhn through unistrut with a cap...?
The unistrut would be slotted...
As long as the particular strut is listed as a raceway you can use it as such. check the manufacturers information.
Roger
I do not believe slotted strut is listed as a raceway, you would need solid strut with a cap and all other parts listed for use as raceway fittings.
I have worked with strut raceway and in the right application it is slick.
