John Fimbianti
When I increase the wire size due to correction factor and ambient temperature do I then have to increase the OCPD to the new wire amperage rating?
No. That is the reason for enlarging the wire size.If you also increase the OCPD then you would have gained nothing as the calculations for correction and/or ambient stipulate your OCPD rating.When I increase the wire size due to correction factor and ambient temperature do I then have to increase the OCPD to the new wire amperage rating?
What if I had a 30amp load and the next available wire after the correction factor andWhen I increase the wire size due to correction factor and ambient temperature do I then have to increase the OCPD to the new wire amperage rating?
