Hi everyone, I have kind of a stupid question that someone asked me and realized I wasn't really sure either.
If you have (3) 32w lamps powered with a ballast that is 90% efficient, what is the total input watts of the light fixture?
My thinking was 3*32w = 96w then because the ballast is 90% efficient, 1/0.9=1.11 so 96*1.11 =106.6 total watts.
That seems correct but then I started thinking that the efficiency is just telling you that of the 96w, only 90% will be used for the actual light and the other 10% is just lost as heat so the input power will still be 96w.
So basically my first assumption is only correct if you wanted to figure out how much power the light needs to get the full lighting output of the 96w but doesent really have anything to do with the actual input watts.
