EMT to PVC Conduit transition
SharpT
New member
Silicon Valley
I have searched quite a bit, and haven't been able to find a direct answer to this question.
I am installing a small 1.4kW PV system on my roof, and my electrical inspector recommended EMT on the roof. My plan is to run EMT about 10' to the eave edge, then install a metallic LB conduit body at the roof edge to head down to the AC disconnect... using a threaded PVC fitting at the LB to switch to gray schd40 PVC.
Conduit includes a 8AWG bare equipment ground wire, along with three stranded 12AWG for the 6A 240V system.
Just prefer PVC, don't want to bend EMT...
SharpT
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
