If use 110 v for a 220 v heater i will get 1/4 the heat ?
Heat is energy. Energy is expressed/measured in Joules. At least it is with SI units.How do you measure heat? Are you talking wattage?
Simple. One volt times one amp for one second is a joule.
I'm working on getting you guys converted!!
Interesting results, eh?Speaking of conversion, this website http://www.unitconversion.org/power/watts-to-joules-per-second-conversion.html gives you a convenient watt-seconds to Joules converter as well as the advertised watts to Joules/second converter. You type in a number in either box and it shows up in both boxes.![]()
Not conventional. It just is.Accepted that conventionally heat is energy.
We Brits gave up on the BTU, British Thermal Unit, decades ago. The amount of energy required to heat a pound of water by one degF....But the output rating of a heat producing appliance is usually specified as the power of that appliance, whether in watts or in BTU/Hour. (The BTU is of course a unit of energy and not power.)
I had some experience with that.Good luck with that.
They tried forcing it on us in the 1970s and that pretty much failed.
"Accepted that conventionally heat is energy."
