rioslives
- southampton, ny
i would like to know if it is a code requirement to carry a ground wire from a detached main disconnect, to a main distribution panel that is located inside a house? there is a belief going around that if your main service disconnect is located on an h-frame away from a structure, you dont need carry a grounding wire from that service main into the structure to the MDP. the though is that, grounding can be reestablished in the structure at the main distribution panel. i would really like to put this one to rest. Article numbers would be helpful too. thanks
