I am in the process of upgrading 3 residential sub panels. I am doing no work what so ever to the branch circuits. the inspector tells me that i need to install arc fault circuit breakers on all required circuits . The inspector tells me that changing the panel IS modifying the branch circuits and arc fault breakers are required. No where do i find a definition on a branch circuit modification. The code as i see it says arc faults are required when extending or modifying a branch circuit. how is a panel change a branch circuit modification? I tried to tell the inspector depending on how the building was originally wired that arc faults might not even set in the event they used 3 wire circuits that share a neutral. Any comments greatly appreciated . this project is in CA
