danishdeshmuk
- India
should i connect the output of digital temperature controller directly to the vfd as a frequency reference or frequency reference command (where we usually connect potentiometer to increase or decrease the speed of a vfd and hence of the motor) ?
Want to control the temperature of the water in such a way that when water is more hotter and more warmer then with the help of vfd the motor (blower/blower fan/cooling fan ) runs faster to maintain almost the same temperature all the time and if its slight warmer then with the help of vfd the motor (blower/blower fan/cooling fan ) runs slower the water flows through the pipe so that the bus bars that are used for induction furnace remains cool not very hot so thay they could damage themselves.
Although there is cooling tower but sometimes we need to shut off the cooling tower because of the cooled down temperature so need to turn on and turn off every now and again and most importantly the cooling tower if not a suitable application to cool down a very hot water. It just practically cools down 10 degree celsius temperature.
i am planning to use a VFD (ABB ACS 800) with a RTD (PT 100) and a digital temperature controller to achieve the desired temperature .
