D -
... OR is merely impossible ?
No, it is not impossible.
First decide your goal:
Are you trying to build one? Are you trying to learn about design that may also have a practical application? If this is just an excercise in learning, that is completely different from buying parts and laying out a control cabinet.
So which one is the best option to achieve the ATS for portable home generator ? ...
I want to switch off my generator's output power & switch on the electricity (provided by the Govt) when the electricity shortage (outage) is over. ...
... i want to completely shut off the generator then
Put together your Design Document listing your specs.
Here's a sample. Probably not what you want - just a place to start.
Assuming gen has an ignition switch, manual start, no battery. All transfers are Open Transition
- Power fail sequence:
- Utility power fails
- manually start gen
- Gen running (voltage on output terminals) interlocks out utility contactor
- manually energize gen contactor. Also interlock utility utility contactor.
Recovery to Utility sequence:
- utility power comes up. Start timer to avoid flickering power at Utility comming back on line. (30 sec - 2 min maybe?)
- Timer opens gen ignition circuit
- Gen voltage falls to 0 (zero)V. Opens gen contactor.
- Gen off 0 Volts, Gen contactor open, Close utility contactor.
Voltage : 220 V single phase
Phases : Single Phase
Frequency : 50 Hz
KVA : Peak Power 2800 Watt and Rated Power 2500 Watt
Power Factor : 0.85
Component specs:
The gen output is 13A peak, 16A at 125%. 20A contactors will be fine for the gen and utility. Probably need 3-5 ice cube relay and a timer.
Or maybe 2 - 2pole, 20 contactors and smart relay, IDEC makes some - throughly programmable.
Need a cabinet, terminals.
Provide for grounding, provide for SDS, Non-SDS. I don't know Indian code, so I can't comment on that.
CB for the Gen main, if it doesn't,
This is just some suggestions You get to be the engineer of record - start with an engineering pad and a handful of pencils
Let us know how it goes.
ice
