- Tennessee NEC:2017
- Semi-Retired Electrician
I know both a pool and outdoor spa/hot tub have to have an equipotential bond around them.
What I'm not sure of is if you have both in close proximity, do the two have to be tied together.
The pool is non conductive and has no rebar or metal so I have to put a #8 bare ground around the pool.
There will be a hot tub close by and it will also have a #8 around it.
Do I need to run a bond wire from one to the other?
