adam garcia
- Spring, texas
Gas Plant Application:
When grounding the BASES of Vessels or Pumps to the SKIDS they are installed on, do you need a PVC protective sleeve over the ground?
I know it is common practice to use PVC Sleeves when going from such equipment to underground ground loop, but am not sure about grounds that stay above ground on top(floor) of Gas Skids.
Not finding in NFPA70 NEC 2011 Handbook, please help.
