Steve_S
- Deer Island, Oregon US
Above ground electrical conduit run, Can foriegn piping such as a water pipe be run in same piping support? Thru a transformer yard.
There is nothing is the code that would prevent that. (assuming that the water pipe does not infringe on the work or equipment spaces required in 110.26)
I disagree, I think 110.34(F) prohibits it.
OP never mentioned switchboards, panelboards, or other equipment that may be subjected to 110.34(F).
OP simply asked if electrical raceway could be supported by same supporting member as a water pipe.
I say yes.
...:?...Above ground electrical conduit run, Can foriegn piping such as a water pipe be run in same piping support? Thru a transformer yard.
