paul
- Snohomish, WA
I want to pick the brains of some of you control guys. I have a 20A 480V 3P temp hydraulic pump skid. The owner wants me to add a reversing switch to the skid, because some of the pin and sleeve setups they use are wired backwards. This is a simple on off application with some hi-temp, low pressure type cut-outs in the control system.
Other than wiring up the receptacles correctly, what are some easy fixes for adding a reversing switch and relays? I've thought of just purchasing a reversing contactor or adding in a latching relay to accomplish this.
Thanks,
Paul
Thanks,
Paul
