ser out of meter socket?
Dg01501
worcester
Hi there, I'm trying to get an inspection on a new meter but there are two exististing meters one with an seu out to the main panel and one with an ser out to a main panel. The mbj's are in the meters. Is there an issue?
iwire
Massachusetts
Where is the overcurrent protection?
You only need SER after the overcurrent protection, unless it happens to be a 3 phase service.
augie47
Tennessee
To me, your question gives rise to many possibilities.
Can you be a bit more descriptive.
You mention a "meter inspection". Are you simply getting an inspection on a existing install or did you install additional wiring ?
You say "there are two meters".. did you add a third ?
What is the location of the panels in relation to the meters (ie: how far do the service conductors extend into the building) ?
Dg01501
worcester
Ok well there were two meters existing with two panels about 15 feet away...I added a new landlords meter and put the panel about 15 feet away with the other panels. So my work is all good but the existing is what I'm worried about. I dont know if the inspector is going to question it
