guyinahouse
- Boston, MA
Lots in the forums about charging EVs from the garage. Not so much about going the other way.
A Toyota Prius and its siblings can supply 120v 30A to a residence (akin to a portable generator) pretty much indefinitely. It's also possible to buy a Prius traction battery-to-AC inverter: http://www.converdant.biz/plug-out/ (and, no, I'm not affiliated) as a turnkey solution, or you could build your own.
Now here's the fun question: under NEC 2011, is this approach a "vehicle mounted generator" and thus a separately derived system? If it's declared separately derived under NEC 2011 250.30 through .34 (and thus requiring a grounding electrode), exactly where would grounding happen? Discretely? Not switching the ground with a transfer switch would effectively use the residence's earth ground, but then that's bonded to grounded (neutral) at the typical load center.
Strictly speaking, the Prius thing is an unbonded inverter, and not even a generator (no mechanically rotating field) at all. It's DC-to-AC, with the option of a local receptacle. It's more akin to a 4kW solar array, except for the rubber wheels of the car completely floating the AC circuit. And that, in turn, begs the question of the "bonding to the frame" answer of 250.34, which Mike Holt kinda answers at www.youtube.com/watch?v=Jj9wXUjya1g in his thoughtful video. Of course, you wouldn't bond to the frame of a Prius, like you might to the frame of a towed generator for a movie set or construction site. It's an odd duck.
So, what to do? Neutral-switching transfer switch and separate earth electrode at the separately derived entrance in the garage? Thoughts?
