davidgarrett
- Greenville, SC
Does anyone have any experience with the power requirements and installation of a tankless water heater?
In certain situations I have actually talked customers out of going with an all electric tankless water heater. If they have natural gas available I will push them towards a gas fired model.
I have done the same ( unless it's one of the smaller (3 kw ) single point ones.)
Most of the folks I have encountered were not happy with their whole-house systems. The ones that were satisfied installed one of the behemoth ones using (3) 60 amp circuits.
Do you consider teenage children a legitimate need?... or where there's a legitimate need for endless hot water.
Hah ! Yes, I've heard that can tend to negate any possible energy savings, since unlimited showers are possible.Do you consider teenage children a legitimate need?
For typical relative COP of the HVAC and the water heater - the former generally 2 or 3, the latter frequently 1 - it's still a loss. And of course there is extra loss in the summer, as cooling load is added.In colder climate areas, heat losses from a tank water heater are not total loss. This heat takes a little load off the heating system.
But you have municipal supplied water. Having to pump your own water would mean you would have been happy even sooner just to have water. Been there a couple times, in fact just this past weekend, no power outage but well motor quit working. Why does things like that always happen on a weekend or holiday?Once upon a time I was a facilities manager and an internal customer came to me asking about heating the infeed to a DI unit. It seems that he could get a significant improvement in throughput by raising the inlet temperature from about 54F (IIRC) to 70F. Based on his flowrates, the power required was rediculous.
I've looked at replacing my current 50 gallon HWH (gas-fired) which seems to be developing a leak or two. I wouldn't dream of going electric. After the Sandy outage, I'm thinking I won't go tankless either, and I'll be looking for a unit with a standing pilot. By day three of the outage, only the fact that we had HOT running water made it bearable.
