jumper
- 3 Hr 2 Min from Winged Horses
Take a look at a Jonard JIC-4366 Cable Sheath Stripper and Ring Tool.
It is easy to use and is easy on the individual conductor insulation.
http://www.google.com/search?num=10...59.6-1.1.0.les;..0.0...1c..6.serp.3gTx7tymOp4
Most cables I have dealt with recently have a string inside of them. Strip a bit of the sheath off and use the string to slit the sheath.
A string in a shielded Belden 4-6 Conductor cable?:?
Rip it with the drain wire.
I use that cheesy Gardner Bendner cat V stripper that has the razor blade and the big hole you stick your finger in. Works great.
Hey! I just clicked on your link. What gives? Was not my description adequate?
I have multiple shielded and unshielded communication cables, 4 conductor #22 to #18, I install into a control cabinet. I needed to remove about 3' of sheathing on each cable.
Looking for a good tool to slit sheath. Something like this. Ideas or recommendations?
I got my second one at my local hardware store; it cost about six bucks. The first one I got free as part of a kit. Hurt me to shell out that much cash to replace it.Your description was quite adequate. My link was just from a quick google search. I have not used the tool I posted.
