Ok you have a 20' foot run of each on concrete and no bends. With the couplings and connectors(compression for the EMT) and straps(equal for both) which takes more labor to install. I think many would automatically assume RGS but I guess how many cut & threads is the determining factor???
i am assuming you mean mounted on a wall,
running horizontally. call it 5' off the floor.
let's pick a common size of conduit... say.... 4".
i can take a square washer, with a spring nut, set
it at the bottom of the pipe, slip half a strap on
the strut, and put a stick of 4" up there myself,
slide a second one into the coupling, put the three
top halfs of the straps on, tighten them, snug up
the coupling, and i'm good to go.
nevermind cutting and threading.
what i want YOU to do, is to stand there with
that single stick of 4" GRC on your shoulder for the
length of time it took me to type this, and then
see if you feel like putting it up on the wall.
and then, BY  YOURSELF, spin the second
stick on to the first one.
THEN COME BACK AND TELL US WHAT YOU
DISCOVERED ABOUT THE DIFFERENCE IN TIME.
