So lets say you bending a 22 degree offset.  You put your protractor on the straight piece pipe, and its - 2 degrees.  So then you put your protractor on the angle, and it says 22 degrees.  So what do you do?  Bend to 24 degrees?  And vise versa your table is +2 degrees so your angle should be 20 degrees?  Thank you for your help.
