extended service
Is it only the meter at the 1st location (no over-current device) ?
pecos, Just for my information, what size wire are you using, voltage and what type load do you have?
ive got a meter 860 feet from new house. do I need ground wire from meter to panel at house or should i use the house eupher ground ?
IOW, where is the service disconnecting means (SDM) located, right?
The answer hinges on this detail. Grounding wire is only required after the SDM.
