Hi
I have searched the code for a reference on sizing conduit for tele/data cable fil and can't find what I need does anyone know where this is if at all?
I have seen labels on some low voltage cables that said, "maximum 100' of conduit, deduct 30' per 90? bend".Fill data can usually be obtained from the cable manufacturer. A rule of thumb is 40%, however fill for communications/data cables also takes into account pulling tension. That's why you need to go to the manufacturer for specs on their specific cable if the conduit runs are extensive. If you only have short runs, say stub-ups into the ceiling through partitions I wouldn't worry too much as long as it easily fits.
-Hal
