Hello everyone. I will soon be working with 3/0 wire. This is a much larger gauge wire than I typically use. I will have 3 conductors so I see that working with a metal enclosed conduit I need 1 1/2" conduit. If I have 4 conductors, then I will need to use 2" conduit. I only have 3, but I think I will go with the 2" conduit just to be safe. Here is my problem. I have a panel mounted disconnect, and the service wire (three 3/0 cables) will be coming in from through the rear of my machine (through the 2" conduit) and will immediately have to make 90 degree turn and fit into a panel mounted disconnect. I have about 4 inches from the conduit opening and the disconnect. Will it be impossible to make this bend in the 3/0 wire? Also, from the disconnect I will then go to a distribution block. What is the minimum spacing between the disconnect and the distribution block? It is open space, but I do not have much room. It is a straight shot to the distribution block so thankfully no bending, but I am looking at only about another 4 inches of space. Is it ok to have such a short run of cable coming from a panel mounted disconnect into terminal blocks? Hope I am making my questions clear here. Thanks in advance for sharing your experience and wisdom.
