SIRSPARKSALOT
 - Northern NJ
I know you are here to learn just like the rest of us, but I have to sound a little harsh. If you are an inspector/AHJ and want to red tag a job that will cost a EC alot of money and its a political issue, then you should already have a code article to back you up before that 'gun is pulled from the holster', much less trying to pull the trigger. Other wise its best to leave it alone.
As others have stated, there really isn't an issue here unless the load is too much.
I fully agree with this and I know it sounds harsh. As an inspector it is your job to know the code. I think that failing someone without knowing the code sections that apply is simply wrong. On the other hand, I have had inspectors tell me they would not pass or fail a job until they did some research. That I think is fully acceptable.
