richbrown
New member
- Forest Lake Minnesota
What will the effect be on a 20 amp 220v motor installed on a 208v system? (Actual voltage at panel is 214v)
You ask a general question and the general answer is- The motor will likely work just fine. Most 230V motors will work on a 208V system especially if it is a newer motor and even more especially if you voltage is on the high side.What will the effect be on a 20 amp 220v motor installed on a 208v system? (Actual voltage at panel is 214v)
What do you mean by 20A motor?? What is the horse power? What is the motor used for?
Maybe. What if it is a single phase motor?
