I have a job to install a 25 kva transformer 480 pri.-240/120 sec. its in a basement of a huge building with no way to drive a ground rod and no building steel or water lines around.
Can I use the grounding from the 480 panel that is going to feed the transformer for my grounding of x-former. It will be coming off the 480 panel ground bar.
Never ran into this before.
Thanks for any help.
