I would too if guaranteed to be properly selected and adjusted. Other than phase loss protection feature I like thermal element overloads better because you don't have operators tampering with settings, unless you have a setting where there is a supply room and additional elements readily available, did have a case one time where they did just that, because there was easy access to a supply of elements.
An expirienced electrician will select and adjust the field overloads properly. It must be everyone else that
comes along and messes with it after these adjustments have been made that's got everyone dogging
the Field Overloads Protection.
