delectric123
 - South Dakota
what type insulation is the most durable, yet feasible for a 200 ft. 50 amp 6/3 extension cord. SOOW?
			SOOW is a reasonable choice for an extension cord requiring durability. I really can't be more specific without knowing the reason(s) for wanting most durable.what type insulation is the most durable, yet feasible for a 200 ft. 50 amp 6/3 extension cord. SOOW?
IMO, for a welder, no. Both have a thermoplastic jacket, which you don't want to use around hot work.i know that i don't want that "J" in the lettering. i need that thicker insulation for durability. this cord is for powering a welder for repair work, and i want to get a 15 year lifetime out of it and don't want it to get stiff and crack. i'm wondering if SEOOW or STOOW is better
Multiconductor welding cable...???We use welding cable for our extension cords. I worked in glass plant and melting end temperatures were way over 100 degrees . Cables never cack and were easy to roll up. We had welding plugs on the I beams.
this is a portable MIG welder.Here is a link to SOOW...http://www.wireandcabletogo.com/Por.../SOOW/6-3-SOOW-Portable-Cord-600V-Non-UL.htmlFor a installation 200 feet away why not use a sub panel & make it permanent. 120V convenience receptacles could be mounted near the panel for power tools also.
