A 75 hp across-the-line starter fire pump trips the secondary overload in the utility pole mounted transformer. We did four to five starts with no problem. Then transformer trips. All electrical inside is ok, no breakers are tripping. Could there be a bad "spot" in the motor windings. Other service on transformer is low, the transformer's not seeing a lot of load. any suggestions about what could be happening or what the next troubleshooting step should be. Utility monitored startup and running of pump and didn't see any issues on their end.
