delfadelfa
- Cincinnati, OH
I am bidding a job to replace existing church lighting. Ceilings are about 20 feet, all wood with big wood beams. Existing lights are 20 - cylinder type fixtures that can be adjusted like a spot light with one 500 watt osram bulb in each fixture. The church is about 100 foot wide by 75 feet. Half of the light boxes are against the walls but I could hang the other 10 lights down below the beams.
They are complaining about the maintenance of the existing fixtures and they do not put off enough light. The heat from the 500 watt bulbs is bleaching the wood ceiling. I don't really want the job so I will be bidding high. If anybody has a fixture web site I can check out or any ideals, it would help. Thanks
