Harley_Squires
- rural West Virginia
I was asked to check out some receptacles that weren't working. Plugged in receptacle tester and the code for Hot and Ground reversed came up. Testing the home run I got 60v. The circuit is run in flex that has this thin non copper ground. Is this the reason it didn't trip the breaker or was there some kind of loop going on through the neutral?
