HankShadwell
New member
I inspected a spa tub whose pump motor had a ground lug attached. Electrician did not bond the motor housing and insists that 680.74 says the ground lug is for all the grounded metal parts (copper supply pipes) and not necessary when water pipes are non ferrous (plastic). I don't see that. The pump is not double insulated. If the pump has a ground lug attached, my take is that the manufacturer put it there to ground the motor frame. Can you comment?
