Ohms law
- Sioux Falls,SD
Are neutrals required in all switch boxes, no matter the circumstance? As in remodels.
Yes it is required unless you can meet the exceptions in 404.2(C)2011
I have a basement remodel, I can easily get to the switch at bottom of stair well. But I can not access the switch at the top of the stairwell, from either above or below without cutting a bunch sheet rock just to drill up through 3 to 4 2by4 plates and running around a shit ton of duct work.
Sounds to me like that area isn't getting "remodeled" much if you don't have access into the wall cavity. If you're just removing and replacing the switch I don't think the AHJ can require you to add a neutral. As always, best to check with your local AHJ
