mastercarl01
- United States
Does anyone have a good definition why we shouldn't quad PV Breakers and they should be on their own designated circuit?
Do you mean that is the only time when you shouldn't be able to use one?The only time you shouldn't have to use a quad breaker is when the main service panel or sub panel doesn't allow the use of quad breakers.
... I believe that this is not an issue because the branch circuit breakers and the PV breakers are using the same stab. ...
