bure961
- Farmingham, MA
I NEED SOME HELP WITH THESE TWIST LOCK OUTLETS AND CABLES THAT SUPPLY POWER TO ELECTRICAL EQUIPMENT. WE HAVE A TOUCH SCREEN THAT TURNS ON/OFF OUR EQUIPMENT. WHEN TURNING THE POWER OFF FROM TOUCH SCREEN OUR WORKERS CAN THEN TURN THE TWIST LOCK TO REMOVE THE 240V SINGLE PHASE BEFORE REMOVING THE CABLE TO THE EQUIPMENT [MOTOR- LIGHTS ]. LOOKING AT THE TOUCH SCREEN IS THE ONLY WAY TO SEE IF THE EQUIPMENT IS OFF. THERE IS NO VOLTAGE TEST TO CONFIRM POWER IS OFF BEFORE REMOVING CABLE , MOTOR AND LIGHTS ARE NOT VISABLE. WORKERS ARE NOT ALLOWED IN PANELS. THIS COMPANY WAS TOLD BY MANUFACTURE THIS METHOD IS SAFE BECAUSE THE TWIST LOCK TURNS POWER OFF BEFORE REMOVING CABLE. HOW DO WE SHOW COMPANY THAT A VOLTAGE TEST IS NEEDED BEFORE WORK CAN BE CONE ?
