JDBrown
- California
- Electrical Engineer
I've got an RFI that I'm scratching my head over, and I hope some of you who deal with this stuff in the field can help me out. Our drawings include the following standard note whenever a new circuit breaker is being added to an existing panel: "Contractor to furnish and install new circuit breaker(s) as noted matching existing in manufacturer, style, type and AIC rating." As far as I know, this is a fairly typical note in the industry. We do it this way because the Electrical Contractor is the one taking the cover off of the panel, and he can see exactly what the existing breakers are, whereas I often have to work from pictures somebody else took at the job site (and they're usually blurry/out of focus).
I now have an RFI from the EC asking if he needs to find refurbished Westinghouse circuit breakers (since all the existing breakers are Westinghouse), or if he can use new Cutler-Hammer breakers. This is a residential panel in a house built in 1993. Now, I know Westinghouse was bought out by Eaton (parent company of Cutler-Hammer) not long after this house was built, and I also know that the Contractor knows this. I'm also pretty sure he already knows if new Cutler-Hammer breakers will work in this panel or not, and knowing that makes me a little hesitant to just dash off a response, because I have to ask myself why the EC is even bothering to ask this question. I'm a little concerned that he's fishing for a Change Order, which has been known to happen, but he could just be trying to prevent trouble with the Inspector (around here they're notorious for nailing Contractors on every little deviation from the signed plans).
I want to tell the EC to just use new Cutler-Hammer breakers, because I'm not a fan of refurbished breakers -- they seem to take forever to get on site, cost a bundle and have a shorter lifespan than new breakers. So... Is there any problem with using new Cutler-Hammer residential breakers in a Westinghouse panel? If this is okay, are the Cutler-Hammer breakers special/different in any way -- in other words, if I tell the EC to use new Cutler-Hammer breakers, is the project going to be delayed while he waits for them to be delivered, or will he be able to use the same breakers that are sitting on the shelf at the big box stores?
Thanks. Man, I've got to stop being so long winded...
