To my understanding that for new construction the EC is required to install a Ufer ground using # 4 AWG and connected to a 20 ft. length of rebar. Ok I got that, than the connection is completed to the meter pan. Now (assuming) that the concrete encased electrode is installed correctly and therefore you have a proper ground. What about the plastic barrier that is installed between the earth and the concrete? Would that not impeed the grounding method?
I also have seen that on some new homes here in FLorida, the EC connects the grounding electrode to a vertical rebar in the wall, is this acceptable?
