jaylectricity
- Massachusetts
- licensed journeyman electrician
I tried a few searches using the forum's search function and google and came up empty after 15 minutes or so.
I am wiring up a walk-in closet. I added a few lights, a ceiling fan and a receptacle to an existing bedroom closet. Since I was extending the circuit I brought an arc-fault breaker to replace the existing breaker.
When I get down to the panel I see that it's wired with a backup generator and a Reliance transfer switch (http://www.generatorfactoryoutlet.com/media/catalog/product/cache/2/image/400x/9df78eab33525d08d6e5fb8d27136e95/3/0/30408.jpg). I don't know for sure that it is wired properly because of the red and black leads, there were leads of both colors being fed from breakers. I'm pretty sure black in the line and red is the load.
At any rate, assuming that my particular circuit was wired properly, I could not get an arc-fault breaker to hold. Is this common? Is there a solution? Or is it obvious that the original wiring in not correct?
