goldstar
- New Jersey
- Electrical Contractor
Has anyone had any experience with these generators ?: http://www.electricgeneratorsdirect.com/Winco-HPS12000HE-Portable-Generator/p1187.html . I have several customers that don't want to go for the big $$ of an optional permanently installed standby unit and they don't want to store gasoline for a portable. These are obviously popular units because they're on back-order until September. Some of the things I'm trying to find out are :
There are towns here in NJ that will either not allow stationary generators or in some cases will not allow them because NG gas pressure is so low.
Thanks
- With respect to plumbing codes - can a NG or LP gas line be run with a shut-off and a quick-connect type flexible hose connected to the unit ?
- If so, where can you purchase such a hose ?
- From what the instruction manual says you will need a regulator and gas solenoid (irrespective of whether it NG or LP) to shut the unit down in an emergency. Are these items readily available ? This site doesn't sell them.
- The unit has a 45 amp, 240 volt output but comes with a 60 amp, 240 volt straight blade receptacle. This particular site only sells 50 amp power cords and outdoor receptacles. Is it permissible to use a 50 amp rated cord with a 60 amp plug on one end and a 50 amp female on the other ?
- Has anyone used these with LP ? If so, what size tanks did you use ?
- All the houses in consideration have NG but would consider having LP installed if running a NG line would pose a possible vioation
Thanks
