n0vahawaii
 - Honolulu, HI, USA
Have you heard of any documented cases of shocks or deaths due to improper use of water pipes as equipment grounds?
It is a common practice in my area for electricians and handymen to "upgrade" 2-prong receptacles to 3-prong by adding external jumpers to nearby water pipes to add a "ground". I have had numerous cases of customers being shocked in the shower, while washing their hands, as well as damage to pipes from electrolysis and arcing loose clamps. I'm going to make a 2017 proposal to have art. 250.130 reworded and to remove the section "(C)" allowance for using the grounding electrode system as a means for equipment grounding. This code is often misunderstood to those who don't understand that only the first 5 ft of the piping is part of the electrode system. I know that that documented deaths have been very persuasive in other code changes and if anyone out there knows of documents case that I can use in my proposal it would really help my case. Also if anyone knows when 250.130(c) was added to the NEC that information would help my argument that 250.130 is obsolete now that GFCI technology exists. Hopefully we can get this code out by 2017 and save a lot of lives in the future.
Thank you for reading.
Keith Baum
Keith Baum
