olly
- Berthoud, Colorado
- Master Electrician
I have a 480v meter pedistal feeding a 480 single phase tranny stepping down to 120/240. Its been a while since Ive wired one like this. I have a few questions. I plan on taking the two phases and a EGC. (Equipment grounding conductor) only to feed it, no neutral. Then from my secondary side taking a neutral and a EGC and phases to a 100a panel mounted real close. Putting the bond in that 100a panel. Therefore only two EGC's in the lug mounted to the case on the tranny (no bond at the tranny). The grounding electrode conductor (GEC) is landed in the 480 meter pedestal by the way. This whole set up is right next to each other. Anyone see anything wrong with any of this. ps I'm putting the bond in the 100a panel because the tranny is tiny.
Thank you for your time!!!
